More sputtering - LEAN
tylerdunigan
Car: 89 240 coupe, 89 240 SR powered hatch, 97 S10 --- SOLD
89 240 Hatch with RB20DET
I've got an S13 with an RB20DET swap. I fixed my last problem 2-3 months ago, that ended up being a corroded ground wire...but now I have another issue. It drove perfect for a couple of months, and when I was leaving work one day, I noticed a little miss. It has progressively gotten worse. As soon as I noticed it, I changed the plugs thinking that would be the problem. It helped for about a mile, and then it started again. I disconnected the MAF, and the engine died...so I'm assuming the MAF is good. I tested all of the coilpacks, and am getting spark from each one. I have a Megan narrowband (worthless I know...will be upgrading in the future), and it is reading very lean, until I get into higher rpms, where it will be on the edge of lean/stoich. I know the o2 sensor needs to be replaced, but I don't think that could cause the sputter like this. It happens at idle and WOT. I hold boost fine, and if it were a boost leak, I should be running rich. I've never checked the timing before, but it has been fine for the past few years, but I'm not sure what can cause the timing to jump. I'm going to take some time today to go through the wiring some more, and see if I can find another wiring problem. The only other things I can come up with would be a bad ignitor chip or CAS. I'm unsure if either of these could be the problem though, since I am getting spark from the coils. My mechanical fuel gauge is reading around 36-38 psi at idle, and I can hear the fuel pump priming.
The motor has an HKS intake/and a Blitz BOV...everything else is bone stock. Still on stock boost too.
Any thoughts?
tylerdunigan
Just for a little update of my next steps...Tomorrow after work I will be pulling all of the coil packs back out. Planning on checking the resistance on each one/inspecting the boots/and painting each in liquid electrical tape. Feel free to throw out other ideas....
