More smoke then ive ever seen an engine make,but runs fine
vicious
Car: 95 s14
My s14 started smoking BADworse then ive ever seen
but its not knocking or making any abnormal sound
i was thinking it was either piston rings, a head gasket, or valve sealsmaybe a pvc valve
but before i pull the engine out can anyone help me out if they have dealt with the same thing
bwscapecod
Car: 1991 240sx
Bad injector, too much fuel...... wouldn't run great, but maybe runs ok?
NismoTypeX
Car: 93' Nissan 240sx FB
what color is the Smoke......ex: Blue=Oil (Valve stem seals or bad piston rings), Black=fuel (bad injector Maf Ground?), White=colant/water (head Gasket is normaly at fault).Also Compression test also works good. the tool is usally 35$ at local autostore
BoBa524
Car: 1995 Nissan 240SX SE
did u overfill it with oil?
vicious
Car: 95 s14
the smoke is white but it does smell like its burning oil
its confusing me
i think it might be coolant thoughim going to pull the head off tomorrow and check it out
thanks
