NY94J30 »
https://forums.nicoclub.com/ny94j30-u126.html
Mon Feb 11, 2008 10:13 am
02 F50 premium, 10/01 delivery date, 57K miles. No history on OCIs or other routine maintenance, though the service records state customer indicated local service.
Records:
-6770 miles, PS airbag/sensor replaced due to air bag lt on dash
-45,575, initiated oil consumption test
-46,198, down 3 qts, metal debris in oil pan, cams scored, failed compression test in cyl 2 --> new long block
-48,031, lower seem on radiator failed after engine replacement --> new radiator
-48,031, CEL since engine replaced --> O2 sensor (bank 1, sensor 1) replaced
-48,301, all belts replaced
-48,783, ballast replaced
-52,853, stabilizer link(?) replaced
-55,706, same ballast replaced again
What type of residual problems might exist after replacement of the engine? I also wonder if the transmission has been taken care of. My sense is with the number of times the car has been in, that if the fluids didn't appear fresh, there would be a transmission flush/brake flush, etc. recommended on the records.
