more reliable?
nismofly
Car: 89 Nissan 240SX Hatch
ok, for a full day at the track (road course, auto-x, etc. that is) what would be more reliable...
ka-t with a small turbo, low boost (200 whp)
or full build n/a ka (also around 200 whp)
slide240slide
Car: 1991 Nissan 240SX KA motor 5-speed
I would suspect the NA version, but let's face it id much rather have a KA-T cause turbo car's are just so fun to drive! they put a big ole **** on your face!
Structure240sx
either one, just depends how well its built
the smal turbo ka-t can be done much cheaper and be as if not more effective.
nismofly
thats what i thought, about the same if fully built, but the turbo would be cheaper to build
w1ngzer0 says na is better because a day at the track would cause a turbo failure...i said no, but ill show him this thread
WDRacing
If your racing in a class, you'll get beat up pretty badly with a power adder and only 200WHP. If your just screwing around, then a T3 with a .63 AR Exhaust housing will work well. You can use water injection at full boost to keep the EGT's way down and you'll stay very safe.
WD
sensibleS13driver
NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA
that's my opinion
klattr1
Car: GT42R powered S14/KA
sensibleS13driver wrote:NA NA NA NA NA NA NA NA NA NA NA NA NA NA NA
that's my opinion
i still have yet to see a DOHC making 200 rwhp on a NA setup without nitrous.
nissanfanatic
Car: 1992 Nissan 240sx SE
klattr1 wrote:i still have yet to see a DOHC making 200 rwhp on a NA setup without nitrous.
Me either.
hysteria
Car: s13 kat, sv650s, and other projects
let me make sure i'm reading this correctly... you're asking whether a fully built na engine will hold up better than a non built turbo engine.... what do you think?
as above making 200 whp without a turbo will be a task and will probably cost more than the turbo setup. plus if you blow up a kat, you can just get another ka for pretty cheap usually.
if in fact you are talking about building either engine whether turbo or not, then i think the turbo option is definitely the obvious choice. but then again i would think the turbo is the obvious choice no matter what...
