d240t2 »
https://forums.nicoclub.com/d240t2-u5383.html
Thu Feb 27, 2003 10:13 pm
Nobody knows the answers to some of the questions...since nobody has done it.
1) We will be doing an RB25DET into an S14 soon. It will probably have hood clearance problems if you try and use the stock crossmember, but I don't know for sure. With custom mounts, you can make it fit any way you like.
2) Should be around 250-280rwhp, but once again, not enough RB25s in the states to tell for sure.
3) It depends on what all the shop does. With our installs, we build a custom intake manifold to better fit a FMIC, build custom mounts, clean and paint the engine, clean the engine bay, and take a lot of care in our wiring, so our shop may be higher priced than others. Not many shops have done it before...so you might want to find a shop that has experience with it (so you aren't the guinea pig). Labor of just a direct swap isn't that much more...it is a little bit more involved, though.
4) Same mods as any turbo engine...upgrade the turbo and fuel system (bigger turbo, maybe manifold, FMIC, injectors, etc). That is the quickest/easiest/cheapest path to more power. Cams and cam gears can be had, too...but there really isn't a stagewise list of things to do, since there aren't a lot of RBs in the states.
5) JWT may be able to reprogram the ECU. We have sources in Australia that can also do it. If it was me, I'd just add bigger injectors and tune with an AFC (for a street car).
Dennis KalmanunStable Hybrids
