fxjackso »
https://forums.nicoclub.com/fxjackso-u250.html
Wed Jul 09, 2003 5:10 am
The actuators are very robust, and rarely fail. I am assuming yours is leaking around the piston, and not the accumulator-small "dome shaped piece" on the side.
Search this site, and the net, for the names of some yards that specialize in Nissan and call them. All years fit, and your chance of a DOA part is very slim. It will not have any nitrogen charge in the accumulator, but neither do your other three. Since the accumulator is flat, you should not have to pay much. They list at about $900-but the one they have is not fully functional because it has gone flat, guaranteed.
And you do not need a consult to set up the system, you bleed it and set the height (if needed) manually. You may need a quart or two of fluid, max.
The job should be no more difficult than changing one shock, and the time to bleed the system. To refill the fluid, pour it in and bleed with the pump running.
Get a service manual and read the entire active chapter before you try anything.
