more probs from me agian
scottsnissan
Car: 1995 240 sx se
I need some one to post a pics of the stock bov and where it reculates.THe way mine is set(i didnt do) comes up from what i belive bov tees into 2 one to the lil silionoid then to the cold pipe.But the prob with going to the cold pipe is that previes owner has a screw into the inlet blocking anything the put the hose on. heres a pic.
All i want to do is get this thing pretty much too stock form so i can drive it.
scottsnissan
Car: 1995 240 sx se
another
Taylor_Durdan
ok ok.. jesus.
1st.. thats not your blow off valve.. thats yourwastegate. disconnect everything that its attached to, and just run it to the large vacuum port above your throttle body
Lucian_rider
Car: Silvia S13 Fastback with SR20DET
You could always just remove the screw in the original cold pipe line and attach the hose to it that connects to the Tee between the wastegate and the boost solenoid. This is how it is stock.
Taylor_Durdan
**** the boost solenoids. one more thing for someone to not wire up or hook up properly. and yeah, you could run it off the pipe, but the car drives better if ran off the manifld
scottsnissan
Car: 1995 240 sx se
So i need to run it right.Off the manifold.Because the guy never gave me anybracket for that.So now what.
