pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sat Jun 07, 2003 11:10 am
your Detonation sensor wouldn't cause the car not to start, your problem might be a power transistor module or or CAS(camshaft angle sensor), these are the most common problems on the CA18 engines that usually brakes down, your MAF even if it is bad, the car will still start, but it won't rev up, it will hesitate badly.
It seems to me that it could be a heat related issue, where I've seen it before, when the engine is cold the car will fire up and when it is worm or hot the car won't start and usually the problem is caused by the power transistor module.
try replacing the power transistor module and the CAS, but first check to see if you have a spark, if not, check your wiring from the engine to the ecu.
Good luck,
PULSAR GTR
