are there any write ups on here for vq45 install or the 350 motorive herd of vq's in 240's and z32 but could it fit in a z31evildky wrote:well since you already said header I assume you have an N/A so the logical power ader is a turbo swap, if thats too much commitiment for you NO2 i a lot of fun and safe so long as you follow the directisn and don't get greedy, a 75 shot will do wonders for you, would likley take 1 second off your ET, and if you're real adventurus, you could always drop a small block V8 in it or a VQ45 or maybe the 350Z motor?
no i dont think their is any write ups but u can try hybridz.org and look around they have some fun stuff to read.jbracy7 wrote: are there any write ups on here for vq45 install or the 350 motorive herd of vq's in 240's and z32 but could it fit in a z31
i did more research on this site +a dozen other sites and now im realy confused ok the vh45 is a low rpm (5500)motor because of it long stroke/heavy crank-the vh41can go higher in the rpm band but has realibity issues past 6500 rpm. ive never even seen a vg33 before or a vg30det single turbo 300zx z32 motor???? i thought all z32 were n/a or twins. where does this vg33 come from i cant find any info on this motorevildky wrote:I don't know if the vh45 has been done in the Z31, and honestly that motor is a huge pain to deal with, here are some varoius z31 swaps form az zbums pagehttp://az-zbum.com/modification.engine.swap.shtml
All 96 and 97 Hardbodies were 4 cylinders. There was no option for a V6 those years. I wasn't sure when they reintroduced the V6 option. I thought it was with the introduction of the Frontier, but I believe you when you say it wasn't until the 99 models.evildky wrote:the Pathfinder got the VG33 when they redesigned it and made it a unibody which I believe was 96, Thr Hardbody was still packing either the KA24 or the VG30, in 98 they introduced the Frontier available only with the KA24 (this was just before the Renault buy in and Nissan was in trouble)
I was unaware that the V6 was deleted in the 96-97 models, I know I looked at the 95 SEV6 in 95 in the showroom when I bought my 90 SEV6, then I was shopping the closeouts in 98 and found the only engine available was the 4 banger, and when the 99's came out, I got another SEV6, I ut a totak of 250k miles between the 2 trucks, the hardbody got 150k of them, it got a waterpump and timing belt, and new tie rod ends and fuel pump, other than that they had regular service, brakes and oil, now I have a Z71, it's had all maner or new parts, thank goodness for warranty, how does cheby get repeat business?NissanSportMag(Z31) wrote:All 96 and 97 Hardbodies were 4 cylinders. There was no option for a V6 those years. I wasn't sure when they reintroduced the V6 option. I thought it was with the introduction of the Frontier, but I believe you when you say it wasn't until the 99 models.
I don't think you have a clue what you're looking at.jbracy7 wrote:im sorry evildky yeah. ive seen these motors up close ant they narrower than a vg30 steaper v shape and a hell of a lot of deck height. the heads are huge. hood clearence is big problem and then theres the funkie looking intake manifold ..............right now im looking into the aftermarket support for the frontier....ps the block is iron heads are alum but its still looks prettie to me
forgive druken typeing i was syked about geting one and hade a tear down party with some freinds and looking at them (sober) not much diff just bolt patterns. "the pathy intake" is that the one that looks like infiniti intake mani (spider legs) cause it does'nt look like a 300zx manijbracy7 wrote:im sorry evildky yeah. ive seen these motors up close ant they narrower than a vg30 steaper v shape and a hell of a lot of deck height. the heads are huge. hood clearence is big problem and then theres the funkie looking intake manifold ..............right now im looking into the aftermarket support for the frontier....ps the block is iron heads are alum but its still looks prettie to me
