USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Tue Jun 08, 2004 7:15 pm
Got a bit more work done today. Still waiting on freakin gaskets... JSpec refuses to answer emails, so I don't know what I am going to do. Had to order manifold gaskets so the turbo will go back on tomorrow along with the new stainless lines. One problem I have seen with them, there is no way I can run the stainless water lines. The water line on the back of the block runs into a nipple on the intake manifold, it is not a screw in type fitting that the hose needs. I may just have to run without waterlines. Anyone else running without coolant lines?
On to the pics.....
Old nasty, dirty, rusty block.....
Cleaned up, wire brushed, and repainted. Gloss black on the mounts and brackets, die cast iron for the block, head was just wiped down.....
MKIII Supra 450cc injectors installed.... They were a bit shorter than the stock CA ones, but somehow they fit and fit real nicely. I hope to god they don't leak.....
Had the flywheel resurfaced at a machine shop while it was all apart. 30 bucks and a great looking flywheel later....
Thats all for today. Tomorrow the intake manifold wiring gets put back together, manifold and turbo go back on, stainless lines get ran, and the newly painted valve covers go back on with new gaskets and also with Hex head bolts to get rid of those STUPID phillips head screws that keep backing out of the valve covers.... More pics tomorrow!!!
Joe
