DRFT24O »
https://forums.nicoclub.com/drft24o-u22197.html
Tue Nov 16, 2004 5:54 pm
Took the **** to nissan, they said the reason the motor shakes so much is because the #3 injector is bad, so i go to a yard pick up an injector from a 1992 (i think) automatic, the #s on the top of the injector dont match my stock ones but i figure thats because it came from an automatic? So i bought new rubber o rings and installed the injector, now the car shakes even more with a/c on and less with it off, not to mention it back fires now (stock exhaust) and has a hard time starting, running rich? When i pull the plug wires out with the car running, #3 doesnt make the car run any different, and the plug is black. I dont know if the cars #3 cyl. works on and off or what, when i floor the car after 5500rpm you can literally feel the power kick in, it feels like vtec. I guess its the cylinder fully kicking in. So someone tell me whats wrong with my car, do i need to do a compression test and go from there or what?OliverOn zilvia.net there telling me to check the impedence of the injectors, how do i do this? so could my clylinder be fine this whole time and the problems is something less minor?
