More issues
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
620 LIL HUSTLER
Car: 1977 Datsun 620
hi guys its been a while. last time i had an issue you guys pulled through for me and i repect that. i got another issues to lay down the lil hustler has been through hell in the past 2 weeks. starting with:~sunday night march 8th it was wet cold snow i went to the gas station and put $2.70 of gas in which is 2 and a half gallons i started the truck and got about a block away and i started to hesitate and had no power. after tampering with it i managed to get it home without stopping AT ALL.~the next day (monday) i went to the truck to start it for school and it wouldnt even start. so i walked to school in the snow. i got home and started to mess with it and couldn't get it to go.~the next day (tuesday) i just got a ride to school and when i got home started to work on it again and drained the fuel tank and took the fuel filter off (there was diesel gasoline and water in the tank[dont ask i dont go to that gas station any more]) i replaced the fuel filter, put premium gas in the tank, and put iso-heat and carb and injector cleaner in the tank. i started it and it ran and smoked (diesel residue) i drove it around and it back fired three separated times (loud as a 12 gauge shotgun) the smoking had stopped after an hour.~the next day (wednesday) i drove it to school and it ran ok untill my curent issue~it snowed real bad monday march 23rd and we had no school and i didnt start the truck~on the 24th the same no school no truck moving.~today the 25th no school but i got the truck unstuck. first i tried to start it for 2 minuits and stopped then i opened the hood and some snow fell on the starter and i found out the starter was HOT and so was the battery.i left the truck for a half hour and tried again it started and ran. after 2 minutes it shut it self off. after another half hour i started it and it ran fine. when i started it today it starts hard and the only way i can start it is to hold the gas pedel to the floor then it starts. i am open to any all sugestions. possibly ignition timeing, maybe engine timing. PLEASE HELP ME
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Wow! sounds like float trouble or moisture in the fuel lines.
I would try isoheat in your gas tank....that will dry out the water if that is the problem. Keep us updated.
620 LIL HUSTLER
alright its good just needed at carb rebuild
Return to “Datsun 620”
