TheOne »
https://forums.nicoclub.com/theone-u18820.html
Mon Apr 23, 2007 6:09 pm
yep, yer missing a cylinder, tho it doesn't sound like ignition, check it like WD said, also check injectors the same way.(pull wire while engine idling, idle should go eratic, if idle still the same then its that plug/injector)
at least my car sounded the same, cause my injector #4 either wasn't firing at all or was firing too much fuel(thus causing it to flood that 1 piston, i believe thats also why my engine spun a bearing, fuel prolly went down the pistons and into the bearings, my oil was black even after a less than 500 mile oil change, but replacing the injector worked....till rod knock got worse)
kinda sounds like a wrx, at least mine did cause of that and i had an exhaust leak after the cat.
Modified by TheOne at 11:24 PM 4/23/2007
