More good news :-/
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Recently I've been having vibrations in the car, especially on decel. Its also been accompanied by a slight metallic sound. So I was really worried and stuff. Well, today I was letting it idle with the hood open and hitting the throttle pulley trying to generate the sound (which was easy to do). I look over at the turbo and guess what? I only have ONE bolt holding the motor mount bracket to the motor! If you look at this pic of my motor, you can see all 3 holding the bracket to the block--
But on mine, the only bolt remaining is the one closest to the front of the motor. The top one and rear one are missing and the bracket itself is slightly rotated. Does ANYONE know the size and thread of those two bolts? I am in desperate need of them right now. This **** is ridiculous.
Bwana
Car: Denali
Couldn't you just take the remaining bolt out and just store the bracket? That's what I've done with mine...
c-rad
Bwana wrote:Couldn't you just take the remaining bolt out and just store the bracket? That's what I've done with mine...
Huh??? Elaborate...
float_6969
Chris, what if you prop the motor up with a jackstand at the transmission caseing up near the where it bolts to the block. The remove the remaining bolt and take it down to the hardware store and match it up?
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
pretty sure they are 10x 1.5mm i had this same problem a few days ago, i was running the motor and noticed it rocking more then normal, turns out when i pulled the motor last i pulled off the mount bracket to get to the pan easier and forgot to put all the bolts back in.
Bwana
Car: Denali
c-rad wrote:
Huh??? Elaborate...
Duh, my bad. Somehow when I glanced at the pic "motor mount" changed to "lift bracket"... not sure how... lol
davidricardo86
Car: 1992 Nissan 240SX SE
Hey Chris, what is your email? Id like to ask you some questions about the headgasket and turbocharger you opted to use. Thanks.
-David
c-rad
davidricardo86 wrote:Hey Chris, what is your email? Id like to ask you some questions about the headgasket and turbocharger you opted to use. Thanks.
-David
Its in my profile dood....
