1dollar240 »
https://forums.nicoclub.com/1dollar240-u221.html
Mon May 12, 2003 2:08 pm
I know its hard to diagnose an engine problem just by hearing my crappy written description, but here goes anyway, thanks for any help in advance.
Once the motor warms up fully it starts to make a sort of metal on metal rattling noise. it could be valve chatter, or maybe a stuck valve/lifter. It doesnt overheat, and only makes the noise under load, i dont think its the transmission, and i've checked the heat sheild, fan shroud, and pretty much any other external accessory that could be rattling. Also, it makes alot of mini- backfire noises from the exhaust when i let the rev's fall while its in gear (like slowing down from 40+). If it runs for more than 8-10 minutes after warmup, it starts idling erratically, and i usually have to keep on the gas a little to keep her running. It doesnt overheat, but if i let it die at that point, it wont start back up, but just crank over very slowly. example: it died on the way home from work saturday night, left it over night and hitched a ride with a friend, sunday afternoon, went to get it and it started right up.). Anyone got any ideas?
