I'll see if the shop can do it..if they can't I'll be doing it as soon as it's working again..if it ever does.hysteria wrote:you should def put a restritor on there, or the pressure will go right past those seals and you'll have a leaking turbo and smoke everywhere again... THEY ARE EASY TO MAKE!!!!!!! so do it!!!! just go to home depot and buy a small allen screw that doesn't have a head it's just like the threaded part with a allen wrench input on top... screw that into the line fitting and drill a 1/16 hole through it and you're done... it takes about 10 minutes if you screw around the whole time... literally took me and my friend 1 minute to complete that once we had the drill bit in and the allen wrenches out and everything. soo easy and it'll save your turbo from leaking!!! DO IT!!!
The clutch is stock for all I know, and no I haven't touched it or the area - the shop didn't either I assume. It's so low it hits the ground alot..and being put up on tow trucks it has scraped and dragged like crazy..so idk maybe something popped - I'm sure the shop will be able to figure it out. I'm assuming it's the clutch, but *shrug* I'll find out soon enough I guess.fiznat wrote:Your motor reving while youre in gear with no spinning of the tires is definitely a clutch or some mechanical linkage related problem.
Is the clutch new? Have you worked on that area of the car at all? Do you get any smell or smoke when this happens?
Just to help you visualize, the way the clutch works is that it is always pressed onto the flywheel (always attached to the engine) until you press in the clutch, which pulls it back slightly from the flywheel. If you are in 1st gear (or whatever) with the clutch out (pedal not up, clutch engaged) and your flywheel is spinning free without spinning the transmission/driveshaft/axles/wheels- then you definitely have a big problem down there. Assuming the driveshaft is not turning, I would think you either have a bad pressure plate or a VERY worn clutch disc.
hmm..well hopefully I'll find out tomorrow, as it just got in the shop today before they closed. It was doing good until I gave it to the dealership when they put my turbo in...so idk. As I said it's about 1 inch off the ground, so it's been scraping and dragging alot - something might of got scraped loose, idk. Hopefully it's nothing terrible. If I need a new transmission or something I'm going to shoot people.hysteria wrote:i've never even encountered a disc that was that worn out... my brothers stock disc was so bad that you had to match revs perfectly during shifts and then ease on the throttle in order for it to transfer power to the ground... and 1st and second had to be done just perfectly... so if you tried to drive it hard, it would just slip and you'd just smell burning. that clutch was as bad as i thought they get, and i've never even seen anything close to that bad before or since then... i wonder if the clutch is the problem... you should be able to feel something in all gears... even just a slight something, but if it feels like nothing at all then i think it's a good bet there is something else wrong, not just the clutch (if the clutch is a problem at all)...
here's the deal with 1st and 2nd... there is more opportunity for the clutch to slip here because the car is not in motion, and it takes much more energy to put something into motion (from rest) than to keep it in motion... therefore it doesn't make sense that 1st and second grab easily and then while you are moving 3rd and 4th wont grab at all... my guess is that there is some other problem...
in the case of my brothers old clutch it would do exactly what i described above... it was much easier to make the thing slip in 1st and 2nd than when you were cruising already and shifted from 3rd to 4th or 4th to 5th.
The guy is supposed to be calling me soon (he's in chicago for the day).ILikeMy240sx wrote:800 does sound pretty steep.. Whats their labor rate and what kind of clutch did they order? Im a bit confused by what they mean by compressor...
check if your coilovers are blown or something by going to the shop and see if there really is oil leaking all around the struts of the coilovers. If your tie rods are bent invest in Tein rods.. I hear they are really good.
Yeah I knew the A/C thing was just a "hey i want more money", not a neccessity - unless they mean the compressor for/on the turbo? but i don't think so...idk just thinking of anything else a compressor might go to.hysteria wrote:the a/c compressor is just an excuse for them to milk more money out fo you... if you don't need the a/c immediately then dont get the compressor from them... just look for someone parting out a car likes yours and you can do the install at your leisure, if it's not a big deal to you... you dont live in the hottest place so if it were me i'd wait on the a/c stuff.
that is outrageous price for clutch... is that $800 installed or what? freaking clutches cost $350+ brand new depending on what you get...
the problem with having people do custom work for you is that they can just name off bullcrap and say "well the rotary girter's busted so you may as well just sell your soul to me".... not that **** doesn't go wrong when doing custom work, i mean i spent well over $200 in misc parts when i did my install, but i mean $800 is some BULL CRAP for a clutch job...!!!!! they have a lift and it takes them like no time at all to do a clutch job on a rear wheel drive car... 240's are easy to do clutch jobs on... sorry not trying to bring you down or whatever i just hate to see people screw with you like that. dealerships... they really know how to screw with you.
Well..as someone mentioned above - it's weird how 1st and 2nd gear work, but 3rd-5th is like I am in neutral.....he said it's alot harder to get a car moving then it is to keep it moving, so if the clutch was worn it'd would seem as if 1st and 2nd would be the hardest and 3rd-5th would be easier...it's the exact opposite for me.hysteria wrote:i really doubt that the turbo leaked oil into the transmission housing and onto the clutch, but hey weirder things have happened... even if this happened i doubt that it caused problems because my brothers rear main seal housing was not tightened down completely when he installed his sr, and so oil was leaking directly into the transmission, and it caused no problems. he noticed it and then took it apart and fixed it... but ehy you never know... luckily it hadn't gotten all over the place so it was an easy fix. well i don't know what to tell you. get some tools and start working on your car yourself. or if not working on it immediately just start learning more and more because it really sucks (as you said before) to be at someones mercy when it comes to your car... i mean custom work just is better done when the person who owns the car either 1) has a lot of money (which not a lot of people have), or 2) knows what exactly is going on and knows how to haggle if there is no way he/she can do the repairs, and needs someone else to do em...
here's to hoping for you but i just think you should be performing a lot of this stuff yourself, with maybe some friends or something, because it's good to know what the hell is going on with your car and know when repairs are necessary or not, and not have to rely on other people. self reliance, in my mind, is something everyone should strive for, but hey we don't have to get into life philosophies here. i'll just say good luck and then i'll shut up. good luck.
hmm..I'll ask about that - thanks.NateDogg wrote:It's all about gearing. 1st and second have gears which make it easier on the engine to accelerate. 3rd-5th are tougher because the gearing puts more load on the clutch to accelerate. Thats the way all clutches are when they slip, so I dont doubt the shop is telling the truth about it. However, it may just need an adjustment, which can be free if you had a few sockets and a bit of patience. If it is grabbing at 'the top' of the stroke when you push on the clutch you can adjust it down and fix it.
Well. I went there and put half of the amount down...so they are replacing my BOV, redoing all my vacuum lines, and replacing my clutch. They'll be putting the same BOV on (blitz) and giving me an ACT clutch. $1450 with all the parts + labor.hysteria wrote:hey, well i know this all sucks but i can suggest a few things to ease the pain...
you don't need racing coilovers ($2000 item you listed before)... they are completely unneccesary on the street. you can get a very good suspension setup (new shocks/struts and lowering springs if you want them) for ~$500-600... if you don't need the lowering springs it'll cost even less... like $350 or so...
if your vacuum lines are all screwy your bov might not be bad... hook up all the vacuum stuff and THEN test the bov, because it relies on vacuum to operate. if the bov is bad that is $100, maybe, and less than that if you can settle for used or maybe not brand name (greddy apexi blitz etc), but of course if you have to have the best of the best then it'll be $150+.tie rods aren't that bad.
if you spend your money wisely and use ebay for some things you can definitely pick ALL of these things up for well less than $1000...
now doing the labor yourself is of course something you might want to look into, because at this point it would definitely have paid off for you to do the labor yourself... but if you just can't do it for whatever reasons then see if it's possible to get the parts yourself and have those guys install em for you...
sorry to hear the bad news, hopefully this is the last of it. good luck
Yup...$400 for labor on the clutch. Very expensive - but VERY good work. Plus this is Wisconsin...there isn't **** around here. Madison and Chicago are the nearest good tuning towns..and I sure as hell aren't paying a tow company to tow my car over 200 miles.rseabrooke wrote:You might as well add a rear main seal to it while your at it. It probably only cost you 20bucks.Dam that shop is expensive I only paid 240 for labor, 320 for a SpecII clutch, 20 bucks for rear main seal and 50 bucks for flywheel resurface.
ya I'm sure it's not that difficult..but I just want the damn thing working...I don't want to **** around with it.Red-KAT wrote:Yeah the shop I go to swaps the clutch for $200.. Its easy enough to do... I just dont like clutch jobs :P
