Hey, Well, stock KA gaskets aren't meant for the pressures of a turbo setup. The exhaust manifold pressure is often up to 40% greater than the boost level you're running, so you can reach 14 psi in the exhaust if running 10 psi in the engine! All that pressure will work at blowing out the stock gasket. Also, if you are going to be taking the turbo manifold off to build up the engine in the future, or if you just need to change something (always inevitably do), then you can just pull this gasket off and reuse it over and over, something you can't do with a stock gasket.Florida240sx wrote:How beneficial is it?Fixing to tubro my ka...although only going to have low boost.But in the future it will be built...
Exactly. The whole reason I got these made was that my own gasket blew out at 15psi, and then the turbo spooled slower, it was noisy, and the boost level I'd reach was inconsistent.Slo_240sx wrote:Very. If your manifold starts to leak you lose pressure going to the wastegate and it won't open all the way and in return you'll lose spool time and the full amount of boost you are running so this will definately help.-Alex
I should be able to have it by then, yes.Florida240sx wrote:I'm getting my Turbo kit first week of July.Can you have me one by then?For KA24DE.Thanx
Sweet, I'll give you a package dealkrayton wrote:Ill be contacting you soon.
Prob grab a exhaust, t3, and wastegate from ya.
keep up the good work!
I've not seen an rb26 maniford bolts but if he does what you suggest here, would they fit the rb26 also?BoostsFed wrote:don't know if you would take this as a good idea or not: why not do two cylinders each piece, because you can flip them around to match the last two runners. will cost much less to make.
Hmm, that may just be a good idea. I was trying to make it as easy as possible to install, but that probably wouldn't make it any harder to do so long as you still had studs in the block. As for the RB26, I am not sure. I'd have to get my hands on a gasket from one to be sure if they are similar or not.BoostsFed wrote:don't know if you would take this as a good idea or not: why not do two cylinders each piece, because you can flip them around to match the last two runners. will cost much less to make.
