themadscientist wrote:CA18DE oil and water pump. As far as the intake pipe, if you mean going into the turbo, it should be close enough to get it on. If you mean leading into the throttle, no, you have to modify that. The redtop intake is aimed different. The S14 SR is a bit more like the CA. For the head gasket, it's not boost that blows them it's detonation. If the surfaces are true, head bolts torqued properly and the tune done well the stock gasket is fine IMO. Studs are nice, but not an absolute must.
yup, and a good way to keep that from happening is a J&S safeguard as I said a few times before
uses a wideband bosch knock sensor which "hears" better than your own ears, have fast microprocessors which has a much faster reaction time than your foot or the stock system.... it's cheap insurance IMO
not really needed for stock or simple bolt ons, but definitely recommended with lots of boost
I have seen it save motors where without it, the motor would have been in pieces... it really does the unbelievable
