more bs....
Fla S13
Car: CARS!
ok well i wired up my sohc maf and now it wont rev past 2k!!!,i cannot figure out wtf the problem is!!im starting to get pissed!and another thing, i do not have the knock sensor hooked up because the harness i had didnt even have a plug for one becuase he was using a defi gauge and had that hooked thru that? could that be it??
DJ
biosehnsucht
check for codes from ECU; most likely the MAFS isn't wired right but you might get a knock sensor code too. sounds like a mafs issue if it doesn't go past 2k
Fla S13
Car: CARS!
ok when i checked it i got 5 red flashes then 5 green flashes? dose that mean perfect running condition?as in code "55"
Dj
biosehnsucht
that means the ecu thinks its ok, which is whack cause if its revlimiting at 2k no freakin way
something ain't right there.. unhook the MAFS see if it revlimits the same or different. hopefully it wasn't miswired and fried ECU, if you're lucky its something else. not sure if knock puts it into limp mode or not, check the CA FSM (avail from zivia.net tech section) and see if it mentions in the EF & EC section what will make it go limp mode and if knock sensor is one of them... I doubt it since it can't use it at high rpm anyways, too much noise so its ignored there.
float_6969
no knock sensor won't but it into limp mode, but it does run the timing way retarded. As far as the 2K thing, unplug the MAFS and see if it doesn't run any different. If it doesn't and you still aren't getting any codes on the ECU, the ECU may be shot. Before you put in a new one, double check that you have the SOHC wired up right. That could fry the ECU real quick...
NeedCAforS13
Car: CA swapped S13 coupe
my ecu was flashing 55 (thought all was good) all day long with a bad maf today, but it was idling like crap... I put on a good one and now it runs fine:)
Sean
float_6969
yea!!! You got it all fixed!
Fla S13
Car: CARS!
dose any one have a stock or z32 maf that i could buy/trade you for, i have an extra block with a just turned crank, and i atra head with everything but 1 intake valve?
Dj
boost_boy
Definitely an AFM issue.
themadscientist
*Cough*VPC*Cough*
drumma022
Hey DJ, I need that crank pulley ASAP. You had told me that you were gonna have the machine shop pull it off. I need a pulley with the magnets installed for the SDS for a customer of mine. He has been waiting about a month now. Call me at 321-695-7258. We have MAF meters here if you want to work something out. I personally have an S14 MAF meter that can get you running if you need to borrow it.
If anybody (Dee) can help me out with a crank pulley with SDS magnets installed, let me know cause it seems like DJ is not returning my calls or emails.
Thanks guys for allowing me to jack the thread.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
youre quite welcome. good luck with your newly jacked thread.
- tim
boost_boy
Ray,
What do you need exactly? Let me know or email me at: [email protected]
Dee
slw240sx
Car: 1990 Ca18det 240sx Hatch
with VPC can you ditch teh AFM?
boost_boy
Quote »with VPC can you ditch teh AFM?[/quote] Send it on it's merry way!
Dee
r34 gtr
ah dayum! i need me one of 'dem!
uh oh, class time, bye-eeee!
- tim
biosehnsucht
But you have to install a MAP right?
Not the sort of wiring / routing issue a MAF can give you, but you will have to buy that one extra part, a VPC alone won't do you any good.
datsunboy
Car: Datsuns
whats a VPC?
GoofyATX240
vein pressure controller. HKS use to make them, but there now discontinued.
float_6969
:withstupbut you can get them on eBay if you keep an eye out for them. I thought it was Vein Pressure Converter, but I could be wrong. It does get rid of the MAFS though. Basically converts it to a MAP sensing system.
GoofyATX240
Yeh you can find them for pretty cheap on EBAY heeh. I plan on getting one the next time one is on ebay.
float_6969
Cool! If you do let us know about it. (I'm sure you will) I've considered them, but I wasn't too sure as to how well they work. Plus I have a Z32 MAFS setting in a box behind me...
GoofyATX240
Ill let everyone know how it works out. I just hope I can find one sometime soon.
slw240sx
think i might get one and sell the z32 i have. I HATE MAF meters especially nissan ones......
float_6969
Jon lives!!! I thought you died man. Where ya been?
Nismo1182
Car: Z06
I think this is pretty neat, a bit costly but same as a VPC but better.
http://xxtuning.com/store/prod...d=215
float_6969
Does sound kinda cool...
