Moonroof drain hose exit location on a 2009 sl
peppermrj
Car: 2009 Nissan Rogue SL AWD
Anyone able to identify where the drain hoses exit? Would be greatly appreciated. In the teens in Pittsburgh Pa and no garage.
Water just puddles. Tried string trimmer line from the top to no avail. Can’t get more than two feet in. Hope to try from the bottom up. Pulled the wipers and cowl off but nothing there.
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Front drains exit under the cowl cover, rears exit just behind the rear wheel wells.
peppermrj
Thanks for the response. I had the cowl off and nothing jumped out at me. It will be on hold as we are expecting 6 to 8 inches of snow overnight. I really don’t want to just duck tape it shut. Right now you have to scrape the windshield both inside and out on the cold wet mornings.
VStar650CL
Technical Expert
Take a look at this diagram, it will give you a fair idea. The front outlets are way up in the corners of the cowl, the driver's side is hidden behind the wiper assembly.
https://www.nissanpartsdeal.com/parts-l ... parts.html
Return to “Rogue Forum”
