OwnerCS wrote:Paul - Does the MOOG part come with a grease fitting?
I can't remember if it was about a Maxima or Q45 where I saw a MOOG part had the grease fitting vs. OEM without.. Of course the OEM are lifetime greased.
I've seen a lot of good comments about MOOG tie rods on Maxima forums.. Though I don't recall seeing anything here.
The MOOG end links look good to me..
Things I consider when venturing away from OEM parts:
1) Ease (or difficulty) in replacement if it fails.
2) Warranty
3) Price
For example, I'm not going to buy an OEM battery becaue a non-OEM wins on all three.
I do not think the Moog outer tie rod has grease fittings, nor does their inner tie rod. Texas Oil did make a post about drilling and installing grease fittings. I will look into that with my spare rack that I have. Oh and for all of you that think the Q45 steering rack never gets dirty, Think again!!! Pictures will follow I promise.
I just want a OEM battery because it has the Infiniti logo!
qship96 wrote:Run with it, at worst it only lasts a few years and you are out the thirty bucks,but I think you will find the Moog to be of comparable quality to the oem part- maybe even made in Japan like the sway bar links.
Very true.
