jfanaselle »
https://forums.nicoclub.com/jfanaselle-u73887.html
Wed Jan 02, 2008 12:11 pm
My girlfriend's Rogue came with factory installed "mood lighting," which is a small amber LED installed between the two map lights that turns on when the head lights are on.
I decided I wanted something like this in my car because it looks really good at night. It gives just enough light to allow you to see what you're doing inside the car in the dark, but not enough to bother you or be noticable if you're underneith any sort of light.
I purchased some amber LED's with pre-soldered resistors on ebay and went to radio shack to pick up an LED holder. Below are some pics:
I wired it into the dimmer switch so it's controlled the same as interior illumination. As soon as the sun goes down, I'll take some pics while it's illuminated. The LED holder is a little on the large side, but I chose this one because it shields the LED enough so that you only see the light it casts, not the actual lamp. Another option would have been to recess it and poke a small hole (that's how it is in the Rogue) so that it shines through, but I wasn't sure I could aim it correctly.
