Month Old Brakes are Grinding!
ChickenDrifter
Car: 1995 Nissan 240sx Se
Okay, about a month ago I replaced my brake rotors and pads on the rear
of my 95 240sx se. And yesterday I noticed that my brakes were making a
weird kind of loose squeak noise when slowing down and about 10mph it
grinds like crazy. I'm scared sh*tless fellas and dont know what to do the
pads are fine. and the rotors felt fine. WHAT THE HELL DO I DO!
Thanks.
zenkistic
Car: 96 240 SE
http://www.zeckhausen.com/bedding_in_brakes.htm
did you do this? ^^ what kind of rotors and pads did you use? did you do it yourself or had somebody else do it for you? can you see any trenches on your rotors?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I had that happen, only when breaking..... it was a hub bearing
ChickenDrifter
It doesnt grind (rub) in reverse brake though. So what the hell i just cleaned them and did the test lets see what happens
Mangid
Car: 1990 240sx sr20 5-speed
you might have a sticking caliper, does it do it on any particular corner, or do all 4 grind?
nismoracingsx
Car: 1993 White 240sx Coupe
Hmm, smells like cheap pads...what brand did you have installed? Is the grinding coming from both sides or just one side?
I had some cheap pads on my 240 in the front, once, and they drove fine for like 10k, then hit a hard spot in the front left pad, and made a horrendous grinding sound until I replaced the front pads.
After driving, are the brakes on one side particularly hot?
Some things to consider..
ChickenDrifter
I just dont know if its the front left or rear left i cant tell and they are both rear duralast pads from autozone. so IDK.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
have you checked the fronts? i know, fukkin obvious, but i gotta ask. the fact it doesnt do it in reverse kinda points to it
