180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Dec 14, 2003 3:21 pm
oic, well if the engine was running before, granted all things are the same I would check out the ignition system and or whether or not your cylinders are flooded and what not. If you hear your fuel pump run at the "on" position, there is probably a problem with your starter, or your ignitor, and maybe possibly something as simple as is your coil pack harness plugged in?
