nissanfanatic wrote:My only question is why are you buying all that cheap hardware and then considering an AEM EMS? I think you would be better off buying higher quality parts and holding off on the EMS.
amen
i think aem ems is overkill for nearly any setup. most wont take advantage of its features, and not only is the unint expensive to buy, its also expensive to tune; call around and ask how much it costs to tune a aem ems.i've owned one and after messing with it for a little under a year I switched to hondata (similar to jwt but it can be fine tuned to your specific setup @ many local shops). it was about a 3rd of the cost and offered everything i needed. my suggestion would be something similar. its basically a standalone, but only alters open loop mode via programmable rom. theres a few new programs for nissans coming out early next year.
imo, p&p or headwork in general isn't worth the money. raise the boost a couple of psi for free and you'll get the same results. i think the money could be better spent elsewhere.
400hp w/ $6k? i'd hope you can make more
