Momentary misfire after hitting limiter.
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
So here is an oddball issue Ive been with. When I hit the rev limiter the car develops a brief misfire. This happens when I'm in park/neutral or under boost. I can throw 18lbs at it and as long as I don't bounce it off the limiter its totally fine.
It seems like its down a cylinder, but then comes right back in less than 10sec. 2 of the coil-pack plugs were broken so they are rtv'd in place. Spark plugs look good. It's hard to tell which cylinder is misfiring because it comes and goes so quick.
The only thing I can figure its either the coil-pack plugs are still loose, an injector getting stuck, or o2 sensors going out(I've never changed them and my tune its really fat so possibly they are starting to foul.)
I dunno if thats anything anyone else has experienced?
NolimitZ32
What injectors are you running? Could it be that they are getting lazy or you're pushing them to 100% and they are having a hard time closing?
zxFarside
03 Suburban 5.3
00 BMW 323
DW 740s
It boosts just fine, when its turned up, it peaks at 20psi and hold 18psi with no breakups and fat afr numbers.
Really as long as I don't wot through the 1-2 shift or bounce it off the limiter in the driveway it doesn't happen.
NolimitZ32
Without looking at your maps its hard to tell but the only other thing it would seem to me is either a lazy O2 or an issue with the tune coming off the limiter.
zxFarside
03 Suburban 5.3
00 BMW 323
I may look at putting in new o2, since it wouldn't hurt to get fresh ones in there.
I wondered about the tune, and its relation to the transmission. I think the rev limit is set at a M/T level and I have a slightly taller tire on, so if it revs too high the trans module gets confused then the ecu gets confused. The trans is also heavily built. If I can lower the rev limit some it may solve it.
Martino
Car: 91 Nissan 240sx
Bumping and old thread, but did you ever figure this issue out? I'm having what seems to be the exact same symptoms and have not been able to sort it out.
