Mom stole car, drove it into a 3 foot puddle, Power steering doesnt work?
Discuss topics related to the VG and VE series engines.
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
im damn surprised it didn't hydrolock.
Anyways what would cause the Power Steering to go out.
fluids are fine. It worked (whining hard) for like 2 miles. Now it dont work at all(no whine, nothing).
belt is not slipping. When i open the reservoir there is NO movement of fluid
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I've seen p/s pumps simply go out and not pump any fluid. Definitely odd that it would happen after being driven into a puddle... maybe just a strange coincidence.
By whining you mean the p/s pump itself, correct? You may just try a new pump because if the belt is still good that would be the only thing left (unless there is somehow some blockage in the lines, being a sealed system though that shouldn't happen).
FoxFire
i have a feeling its the rack after looking under my car today.
theres a big puddle of fluid under where the P/s rack piece is...
she must of crushed a line or something. which made the pump go out
post by tonight about it....
edit.
its the rack that went... dripin fluid like a mofo from the cover boots
Modified by FoxFire at 1:26 PM 1/28/2008
mtcookson
1992 Iinfiniti Q45
and much much more
That's interesting. I've not messed with the rack all that much so don't know its inner workings, is it just a seal that went?
FoxFire
not sure yet but when i turn full left, it leaks a stream of fluid and it drip bad it any other postion.
looks like ill have to live with it until the engine goes which wont be for a while
mtcookson
1992 Iinfiniti Q45
and much much more
Ahh, that bites.
nghtrain88
Car: 1991 Nissan 300ZXTT
there's a couple lines, two that i can think of, that connect to the rack on the driver side.. you can find them in this writeup in the first picture (kind of crappy picture but with that and the description you should be able to find them): http://www.twinturbo.net/net/v...01512
try to check and make sure those are connected/still in contact
Return to “VG30 / VE30 Forum”
