thanks I was unable to find that section in the FSM before. Its still quite technical for me, but Im sure with your help I can do these 2 tests that seem relevant. I dont have the Consult II tool that they talk about alot I figure that is for dealerships. The first test I see is a simply voltage test of the swirl solenoids electrical connector. Is this as simple as it seems??
Then 10 pages later (which all seemed to be the same test as I posted above) I see this MAF voltage check, I dont quite get where it is saying to test though, do I actually have to find my ECU and disconnect its connectors to test pin61?? I would like to do this test aswell
Thank you for pointing me to page 460 in the FSM, like I said it is a little advanced for me but I would love to have me and my husband try this tomorrow. Is there any other relevant tests?? The vacuum lines are new that why I would like to test these voltage to make sure they are getting the proper signals
Thanks so much so far!!
