moisture in headlight
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
wondering how to get the moisture out of my driver side headlight??????? ps--a very easy way!!! jeff
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Easiest would be to give me the car and a blank check! Next best would be to remove the bulbs and squirt a hair drier in one hole and let it exit the other until the moisture is gone.
nuQ
i will definitly consider giving you my car and a blank check, just don't cash it until tues.,,,promise!!! will first try the hairdryer thing!!!! thanks jeff
Eswift
Car: should be obvious enough
you could also just take the bulbs out and let the water evaporate on a day that isnt too humid.
Q451990
You need to figure out how it got in there too... the older Q headlamps are very well sealed. Moisture is not a common problem until 1997.
Heath
getatu
Car: wine/women cars and song
Q451990 wrote:You need to figure out how it got in there too... the older Q headlamps are very well sealed. Moisture is not a common problem until 1997.
Heath
THAT IS SOIOTRUE HAD THE DEALER REPLACE MY 97 HEAD LIGHTS TWICE
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
My 1995 have numerous flaws (fissures) in the plastic housing of several light assemblies. Epoxy works well after clean and dry.
