ThisIsSparTTa wrote:If you're in Denver you should stop by Woody's shop sometime.
Do you know the name of the shop? That'd probably be really helpful, most people have never even heard of this car from what I've found.ThisIsSparTTa wrote:If you're in Denver you should stop by Woody's shop sometime.
pulsar57 wrote:Thanks for the responses. Yea, I'm not thinking about doing a ton of mods (if any), but just some simple stuff I thought would be pretty fun to do. I don't need the car to be a million horsepower like some people seem to prefer. It's already quite fast as is. I've actually already passed emissions in Denver (which is where I bought the car), I know they did pop the hood, although I don't know what they were looking for, or what purpose it served. I was really just trying to think ahead for the future and save me some headaches down the line. I was thinking about downpipes possibly since I may have to have some leaking looked at in that area, so while they're there it might be worth it.
I'm really just a complete newb when it comes to cars and modding in general, so hoping to learn some and do some research before I get too involved. That's why I was asking about emissions, I don't find the idea of having to remove mods when it comes time for emissions very appealing, so I wanted to make sure ahead of time.
I posted a picture on another thread, the car is very clean (both interior and exterior), it runs very nicely and I have very little complaints so far! I really love my new Z.
ThisIsSparTTa wrote:Not sure of the name of Woody's shop but his info is at the bottom of this page, along with others: http://z32.wikispaces.com/Service+Centers
I'll have to check, it may have been done before I got the car.ThisIsSparTTa wrote: Have you replaced your injectors with new style yet? If you have a 91 with original 370CC injectors you're just waiting for them to fail. You can either keep replacing with old style, or replace all with new style. When going new style, you could go with 370CC, but a lot of people go with Nismo 740CC. I say all this, because if you're going to upgrade your injectors, you would need to get a base tune for the new size (not if you go 370CC). http://z32.wikispaces.com/Fuel+Injector
Ahh, I guess I was being a little optimistic then. That's okay, I'm not really looking for insane speed anyways, the car is already very fast and fun to drive as is, so whatever improves it, even if a little is worth itThisIsSparTTa wrote: I doubt you'll make 400bhp with what you've described so far. I was dyno tuned by SpecialtyZ in March to 360rwhp @16.5PSI, so probably a bit over 400bhp with: Dual Selin Intake, UR UD Pulley, 740CC injectors, BKR7EIX plugs, Greddy Profec Boost Controller, Full 2.5" downpipes>high flow cats, lightweight flywheel upgrade clutch, stock turbos. She pulls like a champ and is a lot of fun. I really need to get some wider wheels/tires on the rear to keep the power down, especially now with the NA rear I have (had TT during tune).
I haven't done a ton of research yet, I've got the main repair I wanted to get done out of the way, so I'll start thinking about it... I was under the impression that the ECU install was just a matter of plugging a new chip in and installing the boost jets? I've obviously got a lot of research to do, I don't want to do anything cheaply or half-way, I'd rather not do it in that case.ThisIsSparTTa wrote: Everything can be installed, and everything can be fixed, just follow the guides. If you're not comfortable soldering the socket on the ECU, find someone else to do it. Its a cheap part, and a relatively easy job for someone in the know. In my opinion, JWT and others have their socketing fee way too high.
Also, consider SpecialtyZ over JWT. They're still doing a lot of work for the 300ZX and have excellent customer service.
Ah, okay I had assumed it was socketed, but that makes sense given the age of the car. After doing a little research, a boost controller sounds like a better idea. I often get up to 12psi on my current boost gauge though, is it misreading, or am I misunderstanding it?ThisIsSparTTa wrote: The ECU is not socketed from the factory. The EEPROM is soldered into place. If you know what you're doing, you can fairly easily desolder the original chip, and solder in a socket to put in other chips.
Also, boost jets are a whole other thing. I'd recommend getting a boost controller over them. Also I assume that means you plan on trying to make near 14PSI, which means you should get an aftermarket gauge as the stock one doesn't do well at the limits.
Just got car back from shop, drives great with the new clutch. Kind of wish I had done flywheel and downpipes at the same time, but it'll probably take me some time to figure out what all I want to get out of this car.ThisIsSparTTa wrote: IMO, do exhaust work before doing intake work. The stock pre-cats and cats are so restrictive that you don't see much gain from the intake until those are able to breath. Saw this recently on a friends car. He went single pop to dual pop with no gains until he put in downpipes and test pipes.
