leifab wrote:I believe a lot of it has to do with shady dyno practices. You can get numbers to "say" alot under controlled environments...whether it be by dyno'ing the base run without air flowing...to get a lower base, or not properly warming up the car before dyno'ing with mods...etc.
That wouldn't explain the difference between G gains, Z gains and AC gains. This type of shadiness as you call it can be applied to any of the above cars so ........
In general it seems that FWD does make a difference in terms of the postion of the intake on the AC (towards the rear of the engine compartment) whereas the G and Z are postioned towards the front of the car. Also the AC intake is directly above the transmission - not sure is that would impede airflow. Also because of the FWD packaging - drive wheels, engine, transmission all sharing the same compartment - leaves no room for a CAI - or an intake that pulls from the front of th car. Does stillen make an intake for the AC?
There are many mods for the Gs and Zs that have been out for some time now and have proven to be effective. It seems relatively easy to add 20 plus HP t the wheels with combinations of WAI, CAI, Intake Spacers,Intake Plenums, Exhausts. etc You would think there would somewhat of a product trickle down of existing (easy-cheap for manufacturers) or newly developed (much more costly for mannufacturers) parts for the AC.
I have replaced my intake with the Pop Charger Z tube combo - the popcharger is a WAI and the Z tube is the actual Nissan 350Z intake tube. The Z tube alone I understand accounts for much of the HP difference between the G and Z engines from the factory. Stillen and other manus. make similiar intakes with similiar performance claims.
Exhausts - I think the G and the Z exhausts are more split compared to the AC. Not sure if there is a power implication here - but consider the fact that Borla only made an axle back for the AC though it seems they forgot to back out the catback price .
Modified by Cali 2 Balti G at 6:06 AM 4/25/2008
Modified by Cali 2 Balti G at 6:07 AM 4/25/2008
Modified by Cali 2 Balti G at 6:59 AM 4/25/2008
