smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Wed Feb 06, 2008 2:56 pm
A carputer is just a small computer like a desktop in a car.
Options for placing the puter are kind of limited, basically to the trunk area, more specifically the spare tire compartment. As for storage mediums, I would personally go with flash memory instead of a HDD, otherwise a laptop HDD such as one from IBM/Lenovo with Active Protection software (or any other brand with some sort of shock-monitoring software that will stop the HDD when shock is detected). I would also highly recommend Bluetooth capabilities for phones, PDAs, keyboards, etc.
As for applications of use, you can connect it to the car's diagnostic port and know exactly why your Check Engine Light is coming on, if it does. You can join your wireless and GPS and log locations with WiFi. As for actual apps, I don't know where to lead you, but I do know there is an open-source interface called RoadRunner.
As for the outside of your car, you could lower it, get new rims, a body kit, exhaust, intake...possibilities are almost endless.
