When I get a little bored, my mind goes down crazy paths. Here is the result of today's boredom.
Let's build an imaginary car, for racing at the TRACK. Here are the mods, as well as the (claimed) HP gains that we'll add to a stock 2007/2008 G35. (These figures from the Internet sites for the items – some simply claimed, others from dyno runs.).
Motordyne plenum spacer = 11-15hp Borla Cat Back exhaust = 10 hp Intake, Fujitsu = 9hp High Flow Cats = 5-8 High Flow Headers. = 9 to 13
Total parts cost around $2200/2500. Plus installation, or not.
Total HP added - 44 to 55 HP. That's a total engine output of 350 to 361 HP. (I'm pessimistic about these totals but let's run with them for today.)
Here is a site for computing ET and Trap Speed from HP and weight.It is asking for Rear Wheel HP. I'm guessing 300 to 320 for our imaginary car, and 270 for a stock 2007/2008 G35.
http://www.dragsource.com/inde...iew=5
The results270 HP, 3750 Lb car. (w/driver and oil and some fuel) = 14.002 @ 97.35 (stock)300 HP, 3750 Lb car. (w/driver and oil and some fuel) = 13.52 @ 100.88 (low HP estimate)320 HP, 3750 Lb car. (w/driver and oil and some fuel) = 13.23 @ 103.02 (high HP estimate)
The car weight is a big guess on my part, but I'd bet it is close.
The Ets are obviously under ideal conditions - temp - humidity - etc., but do not seem overly optimistic. The Trap speeds seem a little slow though.
So how much faster is the modified G?103.02 (the max from above) = 151.36 feet/second. 97.35 (the stock results from above) = 142.78 feet/second
14.002 (stock ET) - 13.23 (quickest ET above) = .772 seconds difference. That computes to a 110 foot lead. (.772secs. x 142.78 fps = 110 feet)I.E, IF, at the TRACK,, the two cars were to race, I would expect the modified car to have a 110 foot lead when it crossed the line. That is about 7 car lengths. (assuming a 15.5 ft car length)
Let's take the stock G35 and cut 150 lbs from the weight - less gas, no spare, no jack, driver dieting - etc. We get270 HP 3600 Lb car. 13.813 @ 98.682 MPHCutting 250 lbs from the G would produce - 270 Hp 3500 Lb car. 13.684 @ 99.613 MPH The math shows that a 100 pound decrease = an improvement of .126 seconds, and .87 MPH.
Our imaginary car, at 3500 Lbs. produces results of 12.93 @ 105.417 MPH
I don't know if the claimed gains are accurate, or if you could ever get a VQ35 to 350/360 HP, without F/I (my instincts tells me that these numbers are overly optimistic), but if it were possible, and IF you liked running at the track it would be a fun experiment.
Obviously, this is imaginary, and your mileage (results) may vary. Feel free to correct anything in the above if you feel it is incorrect. One more thing - Drive safely and responsibly.
