Goofy: For a start you have a base fuel pressure of ~42psi, you also have Xpsi boost to be added to that. so 10 psi boost, you have 52 psi.As a rule of thumb (which you will find listed online) devide cc by 5 to get hp per inj.. it works in real life, not online clacs.
Wulfgang: we made ~205hp atw on a Rb20 the other day at std boost with filter and exhaust. (151kw atw IIRC) (printout avail)That was acheived by a little more timing via the CAS as it was orginally retarded.The AFRs were in the 9s!! we have since pulled the mixtures out to 10.9-11 in the top end and it goes ALOT better... I mean ALOT! I'd expect it to be 165kw atw now... with more avail.This was done in experimentation with a OLD single dial Apexi AFC, 10% out (max for unit)Std pump, std fpr, std boost, std turbo..
If you run 8:1 AFR as I have seen from some factory Nissans with light mods, then you will make LESS power than 12:1 and also run higher duty cycles.
I know of vehicles running 380hp atw on 444cc injs.. on std fpr.600hp atw on 720cc injs at std fuel pressure running 1:1 boost compensation.Work that out on the (cc/5)x #cylinder forumla..
Another example was a RX7 I was tunign a few weeks back.. injs duty cycles were ~90%, and the owner was going to throw some bigger injs at it.Once tuned on the current injs, the car made about 15% more power and duty dropped to ~82% by pulling the mixtures from 8.8:1 up to 10.5:1... car was making 400rwph, now ~455 so effectily by getting the mixtures closer to what they should be, you have removed 10% of the existing duty on the injectors.
AFR has a BIG influence on duty cycle.I wouldn't look at upgrading any injs unless you KNOW 100% you have good AFR, and the duty is getting ~90% and you want to add more boost to it.
