modifying stock driveshaft for s13 with rb25
1GayDrifter
Car: s13 91 sr
i have a s1 rb25 swapped into my 89 hatch and was wondering if anyne has modified their stock ka driveshaft t fit on the rb. i already know that i can buy a new one piece driveshaft, but i rather see what i can do with my stock one first. has anyone done this or know a site that could tell me how to do it?
thanks
imotion s14
Car: 1997 240SX
You need the correct yoke. Search.
mattleegee
Car: s13+19 corolla
i know my rb one was WAAAY shorter then my stock DOHC MT onejust get a one piece
kpnitrl
As mentioned, you need either the RB or z32 yoke. Unfortunately on the the 240sx driveshaft the u-joint is not interchangable. Some u-joints are held in by a c-clip or something of sorts, but not the 240s. So, in short, just get a new 1 piece. I suggest the driveshaft shop or shaftmasters
8gti9
Car: '91 240sx rb25det, '94 Passat VR6 Wagon, '06 Sentra Spec-V
3103-30 slip yoke
RB20DET_240SX
Car: 240SX 1990
i was just going to grind my stock one down wer you bolt it up at until i get the money for an aluminum one.
Sil240
Car: Nissan S13 "The One Cam Wonder"
RB20DET_240SX wrote:i was just going to grind my stock one down wer you bolt it up at until i get the money for an aluminum one.
If you have a RB20 then you shouldn't have to worry about this.Unless you have a RB25 Trans.
If you have a RB25/Trans then your wasting your time and a stock Dshaft
gheydrifter - LOLYou wasting your time and effort.SEARCH and then just buy a 1 piece
Cameron
Car: a 240
just take it to a drive shaft shop, my local one charges around 150 for a steel one piece.
roadrunr
Car: 1992 Nissan 240SX Convertible
I have a S1 RB25 Automatic in a 92 vert and the KA yoke fits into the RB transmission, yes it says RB on the transmission, so far I have shortened it 1 3/4" and its still too long, so I'm taking another 1/2" off, which will leave me about 2 1/2" of yoke in the RB transmission, so it should work, if not I go get a one piece but I figured it was worth a try.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Why keep the old 2 piece one?! That thing is heavy! It weighs 2 or 3 times and much as my aluminum 1 piece. It's a weight reduction all on its own. Less spinning mass = better response.
roadrunr
Nevermind, it wont work anyway, the RB sets back way too far, calling drive shaft shop in the morning.
phulawless
Car: 93 240sx vert, 04 350z
hey roadrunr, i was wondering if you have the measurements for the auto rb25 driveshaft into the convertible...im doing the same swap and that's my final peice to it. also what mounts are you using if you dont mind me asking. thanks in advance
