I recently purchased a T28 for a really good deal. I bought it knewing that it needs work. The exhaust housing has a crack in it right at the wastegate. I did some research on it and after comparing pictures on the net, I finally found out what I had bought. A Garrett TB2804. Here's the specs:
Part#: 465997-0001Turbo Part Number: 14411-54C00Description: Std T25 ConfigModel: TB2804Compressor HousingDiameter: 60Trim: 60 A/R: .60Turbo HousingDiameter: 53Trim: 79A/R: 0.86MSRP: $1,102.10
....Now, I was told that it's more than likely possible to swap my CA T25 exhaust housing with this but the sizes seem quite different. Here are the specs of our T25's:
Part#: 466073-0008Description: Std T25 ConfigModel: TB2209Compressor HousingDiameter: 51Trim: 60 A/R: .48Turbo HousingDiameter: 47Trim: 69A/R: 0.69MSRP: $964.34
Now, if I were to swap housings, how much of a power loss would we be talking about? Also, I would assume that I would have to purchase both a T25 and T28 rebuild kit? Also, is there any other turbo out there that uses a .86 or .64 turbo housing that I can swap with? Also, right from the garrett website:
http://www.turbobygarrett.com/...1.htmIt says there was an option if you wanted the .64 or .86 housing.
Any insight on this matter would be a great help.
Thanks!
Modified by DjLiquid at 1:11 PM 5/10/2006
Modified by DjLiquid at 1:14 PM 5/10/2006
