We recently changed some provider stuff behind the scenes, and are having some transition challenges, but I promise it's being addressed. I know that doesn't make it more fun to use the site, but I wanted to let you know that it's being addressed - rather than the site being neglected.
- Not necessary. It varies based on refrigerant pressure, vehicle speed.I read in the FSM that when the AC is on, the fan defaults to high speed.
- Overheating to mean, the needle on the gauge climbed all the way up to H?This past summer, when the car kept overheating every 45 minutes while driving it on the freeway,
- As referenced above, the fan could turn as slow/fast as 700 rpm. You'd probably need a strobe light to verify speed, because that could look like slow to one person and very fast to anotherI confirmed that while the AC was on, the phone was turning extremely slow.
- Seems like it runs hot to me. My Nissans have been typically a tick below the 9 o'clock or middle mark.As of late, when the car has been turning itself off, the temp gauge needle stays at normal operating temp, with the needle just above the 9:00 spot on the temp gauge.
- How do you determine it's running hot when you're under the hood?But when the car shuts itself off (fail safe mode I'm guessing) and I open the hood, it appears to be running hot. Coolant is low. Reservoir is full. However, I can stick my finger in the reservoir, and it's not unbearably hot. Can leave my finger in the coolant.
- 2 coolant sensors. One at the bottom left of the radiator, and another behind the left cylinder head.So, it seems, there is one temp for the fluid in the reservoir, and another temp for the coolant in the either the radiator, or the block. It's making me think that the radiator may be clogged up, and the clog has gotten worse. To the point where now the temp sensor on the radiator is getting exposed to hot coolant.
- Did you replace the thermostat with an OEM part as well?The water pump was replaced, by me, in 2015, with a dealership part. It could be faulty, I'm not sure. I replaced the water pump because the one that was in there was leaking fan fluid, badly.
- Camshaft sensor issues manifest in different ways (refusing to start, dying at idle, dying on the highway, etc) and sometimes these things happen without a code. for example thisP0340 - I'm not sure I have a starting issue. The car starts perfectly fine. Except after it runs hot and cuts itself off. I assume this Fail-Safe mode. Otherwise, no starting issues.
Yes, last summer when the car overheated, the temp needle would climb almost to the top.
Does the fan have more than two speed settings? When the fan solenoid was plugged in, it would be at half speed, (unless if the FSM is incorrect about the fan having two speeds). I had to take the air intake off (above the radiator) to look and see if the fan was moving at all. And it was. Once I unplugged the solenoid, you can hear the air blowing with the hood closed. Unmistakably faster. No doubt about that.
I can't debate that. Since I've owned the car, the needle seemed to always been at just a tick over the 9:00 mark. It could have always been running slightly on the hot side too.
The shut off issue just started. I assume it's related to engine/coolant temp, as it will only start again after approximately 10-15 minutes. I won't open the radiator cap immediately after shutting the car off, or after it shuts itself off. I'm assuming its running hot.EdBwoy wrote: ↑Wed May 01, 2019 8:28 am- How do you determine it's running hot when you're under the hood?
- If you can shut off the car and immediately open your radiator cap to verify coolant level in the filler neck (without splashing hot coolant), there is a problem.
- For a fail-safe condition, does the gauge show as max temperature or the center display say "engine over temperature" or a similar message?
I have replaced the thermostat with an OEM from Infiniti
I can understand that. I'm thinking if I put the OEM diff back in, plug the diff sensors back in, plug the fan solenoid back in, etc... None of those other codes will pop up. But the overheating will remain.
I would like to grab a bluetooth dongle. Does anyone have a link to a good one on Ebay?
You were correct. My temp needle is normal at just below 9:00, not above it. I had that part mixed up.
I know I haven't fixed the overheating issue. I've just applied a bandaid of sorts. Specifically, when I unplugged the fan pump solenoid and it forced the fan to blow at high speed all the time. And since the past several days, something else has developed. Codes keep popping up, P1480, P1720, and P1772. The first, being the fan pump solenoid. So I've plugged that back in. The three codes stopped popping up so far. I did flush the heck out of the system about two weeks ago. I will be keeping my eye on everything, to see what's going on.EdBwoy wrote: ↑Sun May 05, 2019 11:25 pmIt seems like you handled your overheating issues already. Maybe I got mixed up, but I don't see any indication of current overheating in what you have posted...
Maybe a leakdown test kit from a parts store will shine a little more light to it.
To answer the head and head gasket job - yes, you can do it with the engine still installed. May he RIP; Dean told me he got this job done and put the car back together: 2004-q-head-removal-t587376.html
... Replacing the cam sensor is easier than about any other troubleshooting step you could take. Is there a reason you don't want to look at that possibility?
... But yes, you have a coolant leak somewhere. You shouldn't need to keep adding coolant. Remove your engine plastics and look around the engine bay. A cracked radiator wouldn't be out of the question.
I had a Y33. This F50 I have now though, is sitting on racing coil overs. They feel stupid, bumpy and stiff, until the car gets up to around 85 MPH, at which point they start to feel at home. Other than the overheating issue I've had with the car... It eats highway and has a voracious appetite for it.
I second this. Get the actual reading using this tool.Q451990 wrote: ↑Thu May 02, 2019 8:07 amIf you aren't using something like Torque Lite with a Bluetooth dongle, I would consider getting that. You can get actual coolant temperature numbers, instead of trying of the dash temperature gauge. Most dash gauges have a dead band in the middle to avoid alarming the driver. By the time it's noticeable on the gauge, the engine temperature has been rising for a while.
