Things you need to "modify":-T25 aluminum intake elbow, Bolts on but needs to be rewelded at the right angle ($50 at the weld shop)-oil return flange, need to slot the bolt holes so it bolts on to the turbo (free if you know how to use a drill)-Oil return hose, need a longer one than what was on the T25 ($0.25 home depot)-Bend oil and water hard lines (free)-You also need to buy a S15 compressor outlet elbow ($70)
Its really easy if you do this with the motor out of the car
Also, i had to have the hotpipe re-angled a few degrees and shortend ($20 + $20) and get a Samco 45 degree bend silicon coupler ($55 or something)
