Do you use it piggy-backed to the regular oil filter, or is that now bypassed? I'm guessing it connects to the old filter mountings but haven't seen how one is connected before.superuber wrote:canton racing oil filter....filters down to 8 microns.
http://community.webshots.com/user/neheadsuperuber
That must make oil change time much easier. The oil change guys curse me when they see my car come in. They always have a hard time with the stock location. I wonder why Infiniti put the filter in such a hard to get to spot.superuber wrote:I put on a filter relocator. The lines run from the old filter mount to the new filter mount.
Yes, it is easy! However canton claims that filter can go 15k to 20k.The filter is just an insert. The blue body is just the pretty cover. I change the filter every 10k, however I have not changed it yetbecause I only have 2k on that filter. I drain the oil every 1k. Usually filter location is an after thought by the manufacturers. Yes the Q is not fun, but it's better than some that are right next to the exhaust manifold, i love the smell of burnt flesh!louiegz wrote:
Yes, 1.5 more quarts. Difficult? You pic,oe location,Put car on lift.pull all bolts out of under car cover.loosen filter.oil all over power steering pump clean off pump.install 20 micron filter.reinstall cover and all bolts.replace bolts lost or broke.drill, tap bolts that are broke.aw, forget that, just leave them out.let lift down.oil leaks out of hose covers and electric looms for 2 days.customer returns with oil leak.return to step one.OR.............................maxnix wrote:I like the blue thing too, but it looks more difficult and potentially more messy to deal with there than the engine. At least there might be some nominal increase in total oil capacity.
In the air filter study Q45tech posted a while back, it was disappointing to see how supposedly high end brands like Baldwin and Amsoil did not fare well against OEM.
Looks cool and sounds cool is OK, but performs best is what counts with smart drivers.
Superuber,superuber wrote:Yes, 1.5 more quarts. Difficult? You pic,oe location,Put car on lift.pull all bolts out of under car cover.loosen filter.oil all over power steering pump clean off pump.install 20 micron filter.reinstall cover and all bolts.replace bolts lost or broke.drill, tap bolts that are broke.aw, forget that, just leave them out.let lift down.oil leaks out of hose covers and electric looms for 2 days.customer returns with oil leak.return to step one.OR.............................
Canton racing filter,lay down rag under filterspin off 8 micron filter.spin on 8 micron filter.
restrictive, yes. it does not have a bypass so all the oil is filtered all the time. It is larger. the oil housing is for a ford filter. the big one, PH8A?You can actually hear the oil going through when you accelerate.It sounds like a jet! I got it from pegasus racing. I change the oil a lotso my oil never gets dirty.Cost?oil relocator $75oil lines $80canton filter housing with cartridge $110filter cartridges $15eachDrewQ45 wrote:
Superuber,
I love that setup. I usually change my filter from up top and have a fumoto valve for easy drain but that filter of yours is much better.
Question, how restrictive is it? Usually, the finer particles it can filter out, the more restrictive the flow, however, I guess that could be overcome with greater filter area and your filter does seem large in comparison to a conventional filter. I wonder how long my new oil would take to turn brown with setup like that? Hmm.... cost????
Good looking strut brace, you got there!superuber wrote:oh well....at least it sounds cool!!!
I am liking the black way more than chrome on resin.Jeff Williams wrote:If somebody would chrome the OEM intake, I think most of the people here would start liking it
http://cgi.ebay.com/ebaymotors...ZWD1Vmaxnix wrote:I am liking the black way more than chrome on resin.
Wonder if any of the "modifiers" have checked the prices on the pieces they are disabling? You really don't want to throw them away.
You will have to explain this as it is not true.Fred D. wrote:The oem design is right next to the drivers side headlight which warms up, also restricting the amount of fresh air (cold and oxygen rich air) to the air intake.
But you are wrong. It is a high pressure area to which the intake opens. There is no enclosure. Nissan did not get 70 ft. lbs./liter by designing an aerodynamically ineffecient intake. Intakes and exhausts can be relatively quiet and still produce optimal power. Check out the Audi R10 twin turbo diesels running at LeMans on the Speed Channel as we speak. Deathly quiet and very fast.Fred D. wrote: I'm talking about the air TEMP., the 1994 Q45 the air intake is routed to the drivers side head light the opening ends in a plastic shroud next to the head light. It doesnt get ambient air when its inclosed, ambient is out side of car not inside a plastic cover. I dont think the oem air intake was designed for power, it was most likey made for sound reduction and then secondly came considerations of restriction vacuum ect.
