Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Fri Jun 08, 2007 3:25 pm
Slight clarification on the exhaust bit... you will always want mandrel bent if possible. The other style (what MOST exhaust shops will do, as very few have a mandrel bender) is called crush bent... exactly what it sounds like, bending the pipe by rolling or crushing it.
Mandrel bent pipe retains the same pipe diameter through the bend. Crush bent pipes get a little narrower in the bends, and don't flow as well.
Usually, because of the size of the machine necessary to make mandrel bends, you can only get bolt-on pre-fabricated exhausts with mandrel bends. (Like the new AEM one that Versaspeed will have shortly). Custom shops very rarely have the equipment, I don't even know of a single one in the Seattle metropolitan area, for instance.
Also, to complete the intake-exhaust system perfectly, you also need headers and a hi-flow cat. I have not yet seen headers available for the V, and a high-flow cat IS something that you want to talk to your exhaust shop about... after you have your exhaust and headers, so they can find an appropriate sized cat (of appropriate quality, NEVER buy a "hi flow" cat off fleabay as they are generally just regular generic cats).
With respect to the springs I would either go Tanabe (track record w/ the TIIDA) or Eibach (track record with every car they have ever worked on ever). It's really hard to go wrong with either of those. However, you will want to pair the new springs with new wheels and tires, and a strut tower brace, to make the best possible handling improvement combination.
As more parts are released for the V, more mods will be available. For instance, other fun suspension mods include stiffer anti-sway bars, performance bushings and end links, etc. And if some company can figure out how to legally reprogram the V's ECU, you can unlock not only the latent power of the V that is lost to its conservative programming, but also tweak to optimize the combination of mods you've put on to get the most power from multiple mods.
That be in the future, though.
