ST240 »
https://forums.nicoclub.com/st240-u459.html
Mon Jul 27, 2009 8:28 pm
Brace yourself for the onslaught of questions:
My 20 is running strange. It seems to almost run better when cold which makes me think that it's running too hot (and the ecu is retarding timing?) , although my pos stock temp gauge doesnt say so (upgrade in the near future). Would a test be trying to run it with the temp sensor unplugged both warm and cold and see what the differences are?
At low rpm when warm it seems to almost sputter and lurch when i give it any sort of throttle, then when it comes on to boost she picks up just fine. Could that be knock? Or is it more a symptom of running too rich.
So back to the point of this post. What are all the modes whereby the ECU retards timing? I have: (correct me if im wrong)
1. High temp via coolant temp sensor2. Knock via knock sensors
Once i educate myself a little further i plan to go nistune which ive read doesn't have a method for monitoring knock unlike PFC. What else can be used?
