Amays U G37S wrote:The only way you don't get the other persons gas is when you release the handle, and it shuts off the main valve going to that pump.
But if 8 people are using pumps, or 16 people are, then theres no way that the tank can open from under ground. There has be a main feed line into a seperate line which goes to each pump. So when 5 people pump 87, and 5 people pump 93, the gas will feed into a larger line, and then into smaller lines which run into the pumps.
uh... what?
So anyway... I guess we are all in agreement that the blend valve isn't in the nozzle, so you're definitely getting a line full of whatever the dude before you bought.
Let's assume that its a .5" feed line going from the pump to the nozzle, and that it's 8' long (96" long). The formula for volume of a cylinder is pi*r^2*h.
SO you get: 3.14*(.5^2)*96 = 75.36 cubic inches of volume in the line, which would mean you get 75.36 cubic inches of whatever fuel the dude before you bought before getting to what you are paying for. That's .32 US gallons.
If you have a 3.5 gallon tank, that's 9.1% of your total tank volume. If you require 93 octane, but the guy before you bought 87, then you have effectively lowered the octane of all the fuel in your tank from an ideal 93, to 92.454.
Not bad I guess, but it only gets worse the smaller your tank gets.
