Model Identification...Strut Installation on 92 Q45
tbird71
Car: 1992 Infiniti Q 45
Hi Guys!
Have what I believe to be a base 92 Q car. How can I determine that for sure?
Also, is there a thread on a rear strut installation on the Q45?
Thanks for your help!
Tom
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes there was. I bet the pictures are gone now. Any Tokico blue for a G50 will fit. Don't forget rubber gaiters and bushings for anti-sway bar if you have one. You will need a spring compressor and don't undo the top nut on the shock before they come out I think was the main caution. The springs are oriented in rotation on the seats.
What about your fronts?
tbird71
Fronts are fine...Just the RR is hopping
Have determined mine is the Touring Model with traction control.
Is there any special things to note differently when doing a rear strut install
with this model?
Thanks for your help, the "president" is almost roadworthy
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No, just don't hit the ABS sensors.
