qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Tue Jun 24, 2008 2:35 pm
How do we "know" the screen is there to straighten the air flow? Maybe it's just there to keep junk from touching the sensor... Are we just assuming it's function because Tech says so or is there some technical data from Infiniti/Nissan confirming this? If you just need a screen to evenly distribute the air across the sensor about any mesh screen should work. It's possible it just smooths out turbulence in the air flow.
Need to wire up a MAF to a meter or o-scope and blow through it with a leaf blower and read output with and without the screen. Also with various bends and straight tubing combinations to see how it is effected. Hmm, might have to try that. I have a spare MAF that's missing the screen.
