with the upgrades you did could you tell a difference in torque response?bigbumpinZ wrote:there is a gain if you do put headers on but its not a massive one, i put new headers in when i put in the catback exhaust system in along with the light weight pulley so i had a hp power gain but i couldn't tell how much specifically the headers gave me. although they dont give you a massive gain there still something everyone gets to gain a little more hp
xclusivez32 wrote:you should post up some pictures of your turbo ls1 swap
As its been found before by many, even with all the bolt-ons you will not get to within 60hp of the TT, if you wanna build a NA then do it and don't let anyone discourage you, if you got big hairy ones throw a 75 shot on it, outside of nitrous however you wont ever see TT numbers.bigbumpinZ wrote:i put on a light weight pulley, along with a catback exhaust, intake was already there, im hopefully going to get up to where the TT is stock once im done with some of the upgrades
3rd.xclusivez32 wrote:you should post up some pictures of your turbo ls1 swap
Hey, thanks Beast...do you have any links to his setup, etc?BeastZ32 wrote:
And Rockchucker had 222whp out of blue at his last dyno. So you actuallycan get more than 210 without major internal work, Dcaff.
