Darius »
https://forums.nicoclub.com/darius-u5470.html
Wed Sep 24, 2008 3:16 am
I'll chime in here with a general rule of thumb I like to follow. Make your car fast before investing in the showy mods. Everyone laughs at a car that's all show and no go.
So, I would go with whatever intake you want, it isn't going to make much difference and you're not going to hydrolock it unless you're a retard. A CAI will allow you to tune for slightly more timing since the cooler air may lower the knock threshold a little.
Next, you will see decent gains with a header and exhaust system.
Next, add cams.
Next, add nitrous.
Last, get a piggy-back tuning unit (SAFC-2 or SAFC-NEO) and get it tuned professionally on a dyno before flogging it.
I'm guessing these mods will quickly take out the automatic transmission dual-mass flywheel and then you can do the 5-speed or 6-speed MT swap.
The crank pulley is a harmonic balancer, not just something that can be replaced with a CNC machined piece of alumninum. Don't waste your money. I put crank pulley's on the same level as a throttle body spacer, worthless.
