TDot »
https://forums.nicoclub.com/tdot-u191641.html
Sun Jan 08, 2012 5:59 am
Behind the brake pedal sounds like a hastle to feed a wire through to the battery. Behind the battery sounds perfect. I assume the cabin filter is that white thing behind the glovebox (so i also assume i have to remove that as well as the battery), 1/ is it a hastle to remove the filter? 2/ is the grommet a tight fit, or do you think there is enough space for a 10 or 13 gauge wire?
thanks.
