http://forums.evowned.com/showthread.php?p=34778
Here is a link about it, the original thread is halfway good, but the comment made later is what I am talking about:
"Another option is to tap the hole you drilled and put a threaded pipe in the hole so you can attach a boost line from the upper IC pipe to the BOV for normal daily driving to avoid compressor surge, and then only run with that passage vented to atmosphere when you are in need of high boost like when running at a track."My friend who recently totalled his GSX was planning on doing this and hooking the added boost line to a valve controlled by his DSM link system.
***Here is the writeup by speedmaster747 on converting an Evo 9 BOV (Similar) without the option for safer daily driving for those too lazy to click the link
________________________________________________________________________________________________________________________
Heres a little modification that will make the valve hold more boost by changing it to full blow off!
1st. Take the valve out of the car.2nd. Take it apart from its flange by removing the 3 phillips head bolts.
3rd. Find the orifice on the inner part of the valve and, using J-B weld cap off the hole so no more boost goes into the bottom of the diaphragm.
4th.Wait until the J-B Weld dries up and then Drill a hole about 3 mm on the side of the blow off ( the side that had the hole in it)
And now you are ready to install it back.This nod shold help you hold boost a lot better, since the boost cannot longer go up that passage, the blow off will stay shut untill theres vacumm on the top of the valve!
note: this will change the valve from by-pass to blow-off, and if you don't mind compressor surge, you can also crush the top some.Enjoy....
Quote:Originally Posted by synterHow much more boost you reckon this Modification will hold?25 psi and conting so far!here is a diagram.__________________________________________________________________________________________________________________________
I repeat once again, this is not my work, this is a writeup on evowned by member speedmaster747
