Got a Aftermarket ACT Clutch for awhile, it still takes alot of pressure to press the clutch , are there any springs or DIY mod for the clutch pedal to make it easlier to press? for those who installed the ACT clutch? did u do anything to make it softer?
I drive a Altima, the stock clutch is so stiff to press already and now obviously it's way too stiff , u think I can just use a bigger Master clutch cylinder and a stiffer springs for the clutch pedals? are most of the nissan/infiniti use the same master clutch cylinder? if u know anythinga bout it , would you give me the part number and stuff. THANK YOU ALOT
would a bigger Master Cltuch cylinder or Slave cylinder help any? what about the NISMO Master Clutch cylinder
