Victor »
https://forums.nicoclub.com/victor-u94029.html
Sat Jul 11, 2009 3:33 pm
I do do any work I think I can do myself, especially if I can save a lot of money doing it. I have done brake jobs, tuneups, changed all filters on the car, alternators , starters, power windows, radiators, belts, shocks, etc. The only jobs I don't do myself are jobs that require expensive special tools, special skills or knowledge, or need a lift, or are so dirty and messy I don't want to mess with it. I taught myself to do most periodic maintenance on diesel and gas turbine generators that we used on the complicated military portable radars I used to work on. The reason I didn't do the gas tank drop is I figured one needed a lift and special jack to support the 3/4 full fuel tank. I couldn't find any info on an actual procedure because GM left the fuel injected engine and fuel system out of the shop manual I bought at the same time I bought the van. It only covered carbureted and diesel engines. Since Haynes gets its info from the factory manuals, the Haynes manuals didn't cover a fuel injected engine either. Since this is the first fuel problem I ever had on the van in 21 years I didn't even know I was missing the info. I spent many hours searching the web and the best I could find was the tanks had to be drained first unless you were lucky enough to have an almost empty tank to start out with. Now after watching this guy I know how to do it with just the equipment a do it yourselfer would be likely to have. I tried syphoning the gas myself but the crappy $12.95 syphon pump I bought in autozone seemed to be disolving in the gasoline and started leaking all over the place.
